Most programs designed for Windows XP will run properly in Windows Vista or Windows 7;
occasionally, you will find one that will not. If you're unable to get a program to operate
normally in Windows 7, try running it in Compatibility Mode.
Perform these steps to setup an application
for Compatibility Mode:
Right-click on the program's shortcut or icon on the disk
click "Properties".
Click the "Compatibility" tab.
Check the box titled "Run this program in compatibility mode for" and select from the
list the version of Windows the program was designed to work with. If you don't know
what Windows version, select "Windows XP (Service Pack 2)"; you can always change it,
if the program does not run with that setting.
Click "OK."
Try running the program again. If you're still unable to use the program, select a different
mode and click other options on the Compatibility tab - i.e., make one change to
a setting, try running the program, make another change, etc., until it runs correctly).
Also, you can run the Program Compatibility
Wizard within Windows Help.
Hope that helps you....
SOURCE: unable to find usb device in media studio
Does your device show up as a separate device in windows explorer? If so you may drag and drop files directly onto it.
Alternatively you can download alternative free media players like winamp and rhapsody which do the same job as media player.
If your device does not show up in windows explorer then you may have a usb problem on your Samsung media player. This is most likely to be a hardware fault which I don't know a free/cheap solution to.
SOURCE: Ulead vedio studio 10
Ulead video studio - is not a free software ! U'll only find demo downloads ...
If u really want it u'll be able to download it through sharing software (strongdc, torrents, etc ...). Though if u afford it ! Buy it !
SOURCE: ulead studio 8 wont run after installing
Hi all
was looking for a fix to this problem after my dad had this problem
with no results on the net.
So eventually after about an hour or so of poking around i finally found a fix to the problem.
Fix
right click start then left click explore
go to program files then ulead video studio
click on the ulead program opening the files
scroll down untill you find the startup file EG: ulead.exe
will have the icon on it it is towards the end of the files
Right click on this file and then click properties then compatibility
then untick all boxes.
this resolved this problem on my dads pc.
Hope this helps
SOURCE: Ulead Video Studio 9 - program crash
let me guess, you are using it on vista?
no help then, otherwise specify ...
SOURCE: create disk fail after using windows 7
I had the same problem with ULead VisualStudio 10. I was able to press Alt-N and page forward even though the Next button wasn't visible.
