Can get LDAP search working on BizHub 350 Multi function copier
A while back we switched form Lotus Notes to Exchange. The Notes LDAP server was turned off and a new AD LDAP server turned up. Ever since then the BixHub 350s stopped scanning to e-mail. I enterd the LDAP server settings that work on an HP document sender into the Bixhub and it will not work. The setup seems very straight forward. I enter the LDAP server settings (our Domain controller) and test the connection. The test is good but when I go to use the scan to e-mail feature on the BixHub I get an error to contact the administrator and check the search base.
5 Network settings
5-52 bizhub C650/C550/C451 (FE3)
Setting up LDAP
Register LDAP servers and specify authentication settings. Settings can be specified for the following.
Setup LDAP screen 1/6
Setup LDAP screen 2/6
Setup LDAP screen 3/6
Setup LDAP screen 4/6
Parameter Description
LDAP Server Name Type in the name of the LDAP server to be registered.
Use the keyboard that appeared in the touch panel to type in the server name (32
characters or less).
Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
change the setting, press the [C] (clear) key, and then use the keypad to type in
the desired setting. (Range: 5 to 1000)
Timeout Specify the maximum wait time for a search operation. To change the setting,
press the [C] (clear) key, and then use the keypad to type in the desired setting.
(Range: 5 to 300 seconds)
Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
Name", "First Name", "City", "Company Name" and "Department" in an advanced
search.
Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
touch panel to type in the address (255 characters or less).
Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
server. Searches are performed by also including the sub-directories lower than
the starting point that was specified.
Use the keyboard that appears in the touch panel to type in the address (up to 255
characters).
SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
server.
When SSL is used, communication information is encrypted.
Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
(clear) key, and then use the keypad to type in the desired port number. (Range: 1
to 65535)
Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
to 65535)
Authentication Type Select the authentication method used for logging on to the LDAP server.
Anonymous: This authentication method does not require a user name and password.
If "Anonymous" is selected, dynamic authentication is disabled.
Simple: This simple authentication method requires a user name and password.
Be careful since the passwords can be leaked over the network.
Digest-MD5: This authentication method can be used on a typical LDAP server. If
authentication fails using Digest- MD5, the authentication is performed by automatically
switching to CRAM-MD5.
GSS-SPNEGO: This authentication method can be used with Active Directory in
Windows (Kerberos authentication).
NTLM v1 and NTLM v2: These standard user authentication methods can be used
with Windows NT.
They can be used for logging on when sharing files and printers.
bizhub C650/C550/C451 (FE3) 5-53
With Kernel for Lotus Notes to Outlook Converter software Lotus Notes to Outlook migration is now not a big task. It is a fast, accurate, and easy to use NSF to PST converter tool. It will support all Lotus Notes and Outlook version. Apart from this it will also help user to migrate Domino Server mailbox accounts to exchange server mailbox and also allow user to save their data in TXT, RTF and HTML file format. To more information about software one can go to http://www.nsfpst.org
Click Start, point to All Programs, point to Lotus Applications, and then click Lotus Notes. Because this is the first time you have run Lotus Notes, the Lotus Notes Client Configuration Wizard starts. Click Next.
On the Welcome page, click Next.
When
prompted, type in the name you set up for the user ID for Exchange
Connector for Lotus Notes and enter the name of the user's home/mail
Domino server. Select I want to connect to a Domino server. Click Next.
On the How Do You Want to Connect to a Domino Server page, select Set up a connection to a local area network (LAN), and then click Next.
On the Domino Server Network Information page, in the Domino server name
text box, type the name of the Lotus Domino server that will act as a
bridgehead between Exchange Server 2003 and Lotus Domino. In the Please provide specific network information to help locate this server dialog box, select TCP/IP. In the Server address field, type the hostname or IP address for the Domino server listed above, and then click Next. This server should be the one that you configured earlier.
When asked if you want the User ID file copied to your data directory, click Yes.
Type in the password for the user ID file.
If prompted to set up Instant Messaging, clear the Setup instant messaging check box, and then click Next.
On the Additional Services page, click Next.
You will receive a message that indicates that Notes setup is complete. Click OK.
Verify
that the selected location is set to Office (should be displayed in the
lower-right corner of the Notes client). If not, select the name
displayed there and then choose the Office location.
