SOURCE: How can I train my cat to use the litter box?
Cats learn quickly how to use litter boxes. Keep an eye on your cat at first and after waking up or eating, place your cat in the litter box. If you see your cat squatting, this would also be a good time to place him/her in their litter box. If they happen to have an accident outside the litter box I suggest wiping it up with a paper towel and placing it in the box. Then take your cats paws and place them in the box - this way they will associate what they have just done with the place where they should be doing it. When they successfully use the box for the first few times, make sure to praise them.
Is there any chance you have recently switched brands of litter? Cats can be extremely particular when it comes to what kind of litter you put in their litter box. If you find one that works, you should stick with it. No need to fix something that isn't broken.
SOURCE: What factors should I consider when deciding what kind of litter to buy for my cats litter box?
With all of the brands and varieties to choose from,
selecting a litter can be daunting. I
have come up with some tips to help you make a decision in regards to litter
features:
I would recommend you check out the LitterMaid litter box. It has two sensors on either side of the box that detect when a cat uses it. After 10 minutes, a rake automatically comes and scoops clumps of solid and liquid waste into a disposable container at the end of the litter box. Keep in mind that this does not eliminate you cleaning the box.
SOURCE: The litter in my cat box clumps up and sticks to the bottom in gooey lumps. Is this normal?
No. Try a better clumping litter brand.
Testimonial: "Thanks. I'm looking into what other brands are available"
For the most part, learning to use a litter box is
instinctive for cats; however sometimes they may need a little extra coaching
along the way. The following are some
tips to help you train your cat to using a litter box successfully.
Place your cat in the litter box after every
nap, meal, play session or any other time your cat appears inclined to relieve
itself
While litter box training try leaving a small
amount of waste in the litter box so the scent can act as a reminder to your
cat as to what the box is for
Find a good location - away from high traffic
areas; preferably somewhere your cat can access at any time of day/night
Do not place the litter box near your cats food
or water
Never punish your cat for having an accident
outside the litter box. Instead I
recommend firmly saying NO and then placing your cat in their litter box and
praising them. This way they will begin
to associate positive reinforcement with the litter box as opposed to negative
associations.
• If you have multiple cats, you should have multiple litter boxes. Like us, cats want their privacy too
If your cats litter box is not cleaned every day, or the litter
is not changed frequently, the odor will build up. Here are some tips that will help you keep
litter box odor at a minimum:
Never put your cats litter box in your own
bathroom. The best location for a litter
box is in a small closet; preferably somewhere you keep your cleaning supplies.
Avoid using hooded litter boxes. No matter how clean you keep it, the hood
will trap odors.
Try lining the bottom of the litter box with a
thin layer of baking soda.
Opt for a clumping cat litter. They make it easier to remove waste.
Use a litter box deodorizer.
Be diligent about cleaning the litter box and
area surrounding it
The following is a great brand of litter that neutralizes
odors upon contact with moisture. I have
noticed a difference since we started using it.
http://www.tidycats.com/Products/PremiumScoop/SmallSpaces.aspx
features:
