SOURCE: Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
SOURCE: cd drawer won't open
No, unless a piece of clear plastic is covering it. If you can hear the motor and see that it is trying to open, it may need a very gentle pry with a plastic butter knife. I do not recommend that unless there is no warranty. I would just bring it back to the store where you go it from.
SOURCE: Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
SOURCE: bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
SOURCE: CD door will not open. Does not respond to the open close button.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
