Refrigerators Logo
Pat Dietrich Posted on Mar 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a smell inside the refrigerator that smells like dead meat. We cleaned the drawers, checked all food inside, to no avail. The stench is horrible when the doors are open. What could it be?
  • Terry
    Terry Mar 25, 2018
    Google.com gives a lot of suggestions.
    In case this prior question can provide any help:
    http://www.fixya.com/support/t8054320-fr...
Jim Goldsmith
Level 3:
  • Master 2,005 Answers
  • Posted on Mar 25, 2018
Jim Goldsmith
Master
Level 3:
Answers
2005
Questions
Helped
736934
Points
6152
Poisonous mold; get rid of all the food in it and, get rid of it!
5 Related Answers
Anonymous
  • Posted on Oct 13, 2008
SOURCE: odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
Anonymous
  • Posted on Jan 09, 2009
SOURCE: refrigerator smells strange
I may have found the problem. I pulled out the Fridge again. The odor was in the water pan.
What I found was that the cooling grills in the front was caked with dust. I vacumed this area but it was not until I got down with a flash light and saw this issue. I took a small duster that uses static to pull the dust out. There was a lot. I will see if the smell starts up again.
Anonymous
  • 725 Answers
  • Posted on Sep 10, 2009
SOURCE: Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Anonymous
  • 43501 Answers
  • Posted on Aug 07, 2010
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Anonymous
  • Posted on Sep 09, 2010
SOURCE: My refrigerator has a strange metal/chemical smell...
Hello - did you ever figure out the metal/chemical smell problem? I seem to be having the same problem in my refrigerator/freezer. It is a side-by-side unit. We were gone over the Labor Day weekend for a few days and when we came back the unit has a metal/iron smell coming from it. Not sure what it could be.
Please let me know if you have any ideas.
My Maytag refrigerator has a horrible smell when we open the door where it is now smelling even when we do not open door.nothing in frig that is spoiled or spilt.very clean inside .this has happened t
Sure the temperature is in low enough? Sure there is not a dead mouse under or behind the fridge? Or even between food or what looks a closed bag or box? Keep looking what can be causing the smell, We can't help. because we don't have eyes on site
Awful smell coming from refrg. ge told me there is no drip pan that i can access. any other solutions? model MBF1956KEG
I live in a trailer park and i didn't have a fridge. A neighbour went to a nursing home and left everything behind so i salvaged his fridge. He was taken by ambulance in january and by march or april i got the fridge. Everything in it had spoiled. The stench of rotted meat was very bad. The smell was similar to a slaughterhouse. Meat juices had gotten in-between the plastic panels. I washed what i could outside using quadrated ammonia, even TSP and hot water... nothing solved the problem. I reasoned that i needed ozone to destroy the smell. They rent ozone machines but a product like fabreeze is made of ozone so i tried that. I had to spray it a couple times over a few days using the one for surfaces. The smell completely disappeared.
Fridge smell and taste makes you sick, very clean and no food in it
Keep it open for a 4 or 5 hours... Then keep some cut lemon inside it.
2helpful
4answers
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
A smell is coming from the ice dispenser. I need to open it.
Unlikely area for the smell to come from since with the unit off, there is no action in this area. Most likely cause of your smell: Residue in drain pan of freezer evap area. Remove panel in back of freezer section while unit is unplugged and clean drain and surrounding areas. Use a high concentration of bleach water and let unit air out completely after this. At some point in time, meat or related substance in your ref/freezer leaked and odor is caused by this as the unit was thawed. Use the product ICE AIDE, available at sears or by an A&E tech to continue to freshen your unit for 6 months. IF meat or some sort of undesirable juice dripped into the ice or door water dispenser, you can take this apart and clean as needed following your parts breakdown at www.searspartsdirect.com after you enter your model number off of the appliance. Make sure you work with an unpowered appliance.
2answers
Rotten smell from Back Of Freezer
Look for a dead mouse. They crawl up inside, looking for warmth.
1helpful
MAYTAG FRIG SMELLS LIKE A DEAD ANIMAL!!
use bleach straight bleach to clean it it will usually kill any odors coming from a refrigerator clean it both inside and out
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
67helpful
8answers
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
Food processor stopped working
hi there is no reset switch follow these instructions and it suppose to work http://www.useandcaremanuals.com/pdf/FP1300-1400Series791.pdf when you used it did you smell a burned stench? is the unit smells still from it? then probebly the coiles are burend - sorry cant help.... http://www.blackanddeckerappliances.com/customercare/home.jsp good luck
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
