Question about Leisure Pool & Spa
I have a Leisure Bay hot tub but cannot figure out how to drain it. Number D2 1874
    Top Expert:
  • Leisure Master
  • 9,906 Answers
Should be a garden hose down at bottom either exposed or remove front panel by controls or pump out with simer or cover pump
Posted on Mar 27, 2018
4 Suggested Answers
SOURCE:
  • 8404 Answers
SOURCE: Bought a used Leisure Bay hot tub and it is wired
Reconsider ... Reconsider ...
My comments are general in nature since you have left out a lot of information to make this answer specific to your model.
What kind of load does this hot tub represent? It is probably heated electrically ... if that is the case, I would guess that the load is at least 50 amps on 220 V, maybe more, possibly less. If you convert to 110, your (amp) load will be at least twice that size! you will have to change the heater and the motor to run on 110, it will just not work as well as when running on 220. You may not be able to run the existing motor and heater on the lower voltage, requiring replacement (if available).
Your tub must be protected by a GFI (rated at 60 amps 220 volts) and the supply wire should be #6 three conductor with ground.
If you convert (if it is convertable at all) you will still need a GFI, it will have to be at least 100 amps and your power wire will be #2. I suspect you will not be able to make the attachment of #2 wire (or even #4, if it is legal in your area) to the tub due to size constraints in the connection box. Go to the store and take a look at these wires on the shelf. Aluminum #2 is the size of your finger and you would need three of them to connect at 110 volts.
220 volt 60 amp GFI at the big box store is about $90.00. Did you get wire with the tub? Is it #6, 3 conductor with ground (red/black/white/green)? Maybe #4? Will it reach your power source?
Unless there is space in your power panel for this large double pole GFI, you will likely have to have a sub panel installed. If you are very clever and skilled at working on power panels, you may be able to do this yourself. I suggest you have this done by a licensed electrician. In any event, I would encourage you to comply with the local codes in your community - which are in place for the protection of you and your family.
Look here for generic information on installation. Look in particular at page 3 of the instruction. http://www.premiumleisure.com/Manuals/nov07/ZSeriesSpaManual.pdf
While the picture shows small wire (for clarity?), it looks like #14 wire to me, in bold print, the instruction says use #6 wire, and it should be copper, NOT aluminum. If it is a long distance from the power panel to the tub, you may want to consider increasing the size to #4 to account for power drop. In this case, you would put a standard 220 V 60 amp breaker in the main panel and run #4 to the GFI in a sub panel that is located at least 5 feet away from the tub. The sub panel should be water tight and be lockable, if out of doors. You could run #6 from the GFI to the tub, if your local code allows.
My friend, just wiring this tub without modification is a big, expensive and potentially dangerous job, requiring expertise, knowledge and patience. Changing the heart and nerve system of this device is beyond the expertise of most home owners, if possible at all. Good luck with your project.
BTW, I am not a licensed electrician, though I do have extensive electrical experience, including installing and maintaining hundreds of power pedestals, residential and commercial wiring and power systems around swimming pools. I am a Certified Pool Operator ... and when the time comes, I would be glad to answer your water maintenance questions.
I do have and did install my own hot tub.
I hope this helps you with your question ... thanks for your interest in FixYa.com. If your found this information helpful, a positive vote would be appreciated.
Posted on Aug 02, 2010
kel1guy2002
  • 3740 Answers
SOURCE: where can i get a
All of Lesiure Bay manuals are listed here:
http://www.spasbyleisurebay.com/ManualSearch.aspx
For reasons that make little sense... they are listed by a name vs a model number.
Polysteel Manual 0.93 MB Jun 2007 Celebrity Manual 0.74 MB Jun 2007 G-2 Manual 3.39 MB Jun 2007 B and C Manual 1.77 MB Jun 2007 DMI Manual 2.12 MB Jun 2007 C Series Manual 1.89 MB Jun 2007 Overseas 5S3 & 9G3 Manual 1.60 MB Jun 2007 Overseas Eclipse English Manual 0.26 MB Jun 2007 French Celebrity Manual 0.43 MB Jun 2007 German Celebrity Manual 0.43 MB Jun 2007 English Celebrity Manual Overseas 0.43 MB Jun 2007 Spanish Celebrity Manual 0.42 MB Jun 2007
Hopefully you can solve the model number mystery and locate your manual using the link above.
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
davidspra65638
  • 9906 Answers
SOURCE: How do I turn my leisure bay tub from EC mode to Standard mode to heat it up?
mode button
Posted on Nov 26, 2017
I bought a used Leisure bay Proshield hot tub and looking for an owners manual
I found a link on Google to download the PDF format. www.thespasyndicate.com or www.SpaParts123.net.
Sep 28, 2017 | Leisure Pool & Spa
Dont know what the name of my leisure bay hot tub is model number on pump says spo7211nca
Okay, those numbers mean nothing, and it's just pertaining to a electric motor that is attached to a wet end, which makes up a pump.
what is your question for this forum, if you are seeking assistance? Do you have a problem with this spa?
Apr 07, 2015 | Leisure Pool & Spa
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
Jun 11, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
I cant get my hot tub outof sleep mode
Try turning your GFCI breaker off then back on, may reset the tub's computer. Works on some.
Aug 18, 2012 | Dynasty Leisure Bay Dynasty Spas
Where can i get a free manual I can download for a leisure bay model number L3300sdrc hot tub?
Kelly
May 22, 2011 | Pool & Spa
Pool & Spa Logo
173 people viewed this question
Top Leisure Pool & Spa Experts
Kardoc
 steve
steve
Steve Slater
Are you a Leisure Pool and Spa Expert? Answer questions, earn points and help others
