On the back of your TV near the center there are 4 threaded holes in a square shape, these are known as Vesa mounting holes for TV stands and Wall brackets, you can get an after market stand, just measure the hole spacing on the back of your TV for example 100 x 100mm or 200 x 200mm etc, and buy a stand with the matching hole spacing.
You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
Assuming a modern TV with a square/rectangular arrangement of holes (i.e. VESA mount) - they're M4, length varies.
Appropriate screws will be in the kit with the wall bracket.
