SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
SOURCE: plunger on thetford c-200 cw
Go to Thetford web site, click on customer support, click on manuals,click on your model # and download the manual. It will be a PDF file. More than likely you have lost power to the toilet or you have a bad motor or the linkage has broke or become disconnected.There are many links on Fixya site to order parts or you can take your toilet to an RV dealership.
SOURCE: The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
SOURCE: I have a thetford toilet in my caravan and cant
Here is a link for the Manual for your model http://www.thetford.com/HOME/PARTS/PortableToilets/PortaPotti365PDFs/tabid/669/Default.aspx
SOURCE: not getting enough water in the tank to flush properly.
adjust the float level,it's a rod attached to lever next to float . i believe it will take a screw driver, look closely there is a+/- indicator
