I have an existing chime, the ring button was pushed, the doorbell will not stop chiming. I had to remove the ring door bell unit. This is not a new device, this was purchased at least 2 years ago. I'm not sure what to even look at, I believe it has something to do with the ring unit itself. I put a door bell button on to test and the ring stopped after the cycle. The front door bell is a chime (Westminster chimes)
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
SOURCE: my doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
SOURCE: Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
SOURCE: wireless door bell rings when no one there
most likely on the same frequency! They have a pretty good range on them, I'd go but a different brand!
SOURCE: 'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
