SOURCE: HDMI compatible?
yes the DVD player will work on it thru HDMI to DVI connector but however the audio is not carried on DVI so you will have to have a seperate audio cables. also the 1080p signal is not supported by this set 1080i only.
SOURCE: Philips DVP 5982 DVD Player USB issues
try formating the thumb drive with a fat32 partition before using it in the dvd player
SOURCE: "Not Supported Mode" on Samsung tv with Philips DVp5990
The solution turned out to be connecting with a DVI-to-HDMI cable.
SOURCE: there is only one 1080 connection in the back of
If you are referring to an HDMI input. you can buy a HDMI switch and be able to select many different sources. start by searching for an HDMI switch on Google
SOURCE: My SuperSonic TV combo want reconize my USB drive
Contact the company for a solution. or go to their web site for answers.
