LOOK UP ON LINE TYPE IN E06 OWNERS MANUAL OR E06 PARTS MANUAL MAYBE ONE OF THOSE WILL SHOW YOU WHAT IT MEANS THE E USUALY STANDS FOR ERROR. THE 6 COULD MEAN THE OVEN OR BROILER OR A CENCER.
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
F1 error code usually means that the oven temperature has exceeded 590 degrees. Usually this means that the oven temperature contol sensor ( or thermostat) has failed allowing the heating element to overheat the oven.
To correct this you will need to fit a new sensor. Sometimes the error code can mean a temporary glitch which may be cured by turning off the power for 30 mins and then resetting but if the problem persists then a new sensor is the answer.
My Maytag oven also has a "Sabbath" mode and you can check your manual to see how to turn it on/off. I have a different model than yours, but to turn the "Sabbath" mode off on mine, the manual says to press and hold the CLOCK pad/button for five seconds.
