Question about Pride Health & Beauty
I need instructions for replacement of the Tiller actuater on my Pride Maxima scoot. Unit is several years old so has an early serial number. S562410803xxxx
    Top Expert:
  • Pride Master
  • 61,847 Answers
SORRY BUT WE DO NOT HAVE THAT INFORMATION EITHER
Posted on Mar 06, 2019
SOURCE:
  • 3567 Answers
SOURCE: idintify model and year
Call your local Kawasaki dealer. He can tell you exactly what youv'e got from the vin number.
Google " motorcycle salvage kawasaki " for parts.
Google " kawasaki service manuals " for the diagram
Please rate this solution. Thanks!
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: wiring has been disconnected need to rewire pride
Hello, If you need any manuals or wiring diagrams go to;
http://www.pridemobility.co.uk/ipb/
Username : pride
Password : access
Hope this helps...
Posted on Jan 27, 2010
kel1guy2002
  • 3740 Answers
SOURCE: What carburetor fits ryobi 410r tiller?
http://www.oscar-wilson.com/MANUALS/BOLENS/21B-121R765.PDF there ya go..
Posted on Jan 29, 2010
cris_p
  • 62 Answers
SOURCE: Replace 2004 Hundai Sonata Door Lock Actuator?
take all screws of ,,then take screws of actuator and cables then remove it ,,put in new one put everything back together
Posted on Feb 20, 2010
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
Battery not charging
Is the charger working? They do fail.
How old are the batteries? They have a lifespan of + - two years.
Has your main charger/ battery fuse blown?
Pride may tell you as they told me that it doesn't have one, nevertheless I found mine below the floor hatch under the foot mat ... and? It was blown. It's a standard 10 Amp car fuse, it cost a few cents and the problem was fixed.
The provider had said that it was definately my batteries and that he would replace them at €157.00 He didn't seem interested when I told him that they were already new! " One of them will be faulty then" he said.
Find that fuse, it's not in the tiller fuse box - but please don't forget that there is a risk of a power short or a bad electric shock be very careful and/ or get an electrician's help.
Apr 19, 2014 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Replacing the throttle boot, I think
hi , I can order the part however i will require the serial number ,
regards
Jan 23, 2013 | Pride Mobility Legend 4 Wheel Electric...
Worm gear has a hard spot, and doesn't turn freely. Tines will run for a short period of time and then stop.
You will probably need to replace the worm gear and any other worn parts in the gearbox. Check your owners manual for part numbers. If extensive repair is needed and your machine is several years old you may be better off with the Mantis trade in program for a new tiller. I found this to be the case with my own tiller last year. Call or go to www.mantis.com.
May 24, 2011 | Mantis Little Wonder Tiller/Cultivator...
I have an old troy bilt pony rotertiller no serial tag
The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
ballping
Jul 26, 2010 | Troy-Bilt Pony Garden Tiller
Where do I find the model number and serial number, it is an old troy bilt rear tine tiller, two speed
The older models do not have an actual model number but only a name to distinguish the size. Early production models include the Horse, Pony and Junior. You must find the location of the serial number tag to order parts that will fit your particular rototiller for seamless replacement of parts. Hope this will help
Apr 23, 2010 | Troy-Bilt Pony Garden Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Brakes start dragging and battery goes dead fast.
First have the batteries load tested. Also with that put a ohm meter on the brake. It should be around 60 ohms.
Jun 03, 2009 | Pride Maxima 3-Wheel 3-Wheel Scooter
I need to know my Pony Tiller model number it is several years old. It has a B&S moder number on it.
look on the trans case on left side if you are standing behind the tiller'. other numbers are on the engine cover serial number ,engine size. looks like htis H35-4556n-ser. 2071B on engine cover. number on side of trans case will look like this 500 30 12-82 BF 2 . 12-82 is the year it was made
May 11, 2009 | Troy-Bilt Pony Garden Tiller
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Health & Beauty Logo
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
