Lands Phones Logo
s
simon estroff Posted on Mar 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WANT TO CHANGE OUTGOING MESSAGE ON PANASONIC KX TG 4131.
Level 3:
  • Panasonic Master 6,688 Answers
  • Posted on Mar 24, 2018
Cindy  Wells
Panasonic Master
Level 3:
Answers
6688
Questions
0
Helped
3529866
Points
21744
The base of your phone system is the KX-TG4131. The handset/base combination packs have a slightly different model number (KX-TG4132 for example). Assuming that you want to change the greeting of the answering system, you need to press Menu # 3 0 2 (when the phone system is in standby mode) from a handset. (Alternatively, press Menu and use the arrow keys to navigate to Answering Device. Press Select and navigate to Greeting. Press Select again and navigate to Record Greeting. Press Select and navigate to Yes. Press Select one more time. When you hear the beep, hold the handset about 8" (20 cm) away from you and speak your new message clearly. Press Stop when finished. The recording will cut off if your greeting is longer than 2 minutes. To exit the menu system, press Off. Make sure that the Answering system is on and your recorded greeting should play when you can't pick up the phone within the set number of rings.
See page 21 or page 33 of the manual. Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tg4132_mul_om.pdf .
I hope this helps.
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Apr 14, 2009
SOURCE: retrieving messages over phone
Using the answering system
remotely
1 Dial your phone number from a touch
tone phone.
2 After the greeting message starts, enter
your remote code The default setting is “11”..
LThe unit plays back new messages
including memo messages.
LAfter playing back new messages,
the voice guidance starts.
3 Follow the voice guidance as
necessary.
4 When finished, hang up.
Voice guidance
During remote operation, the unit’s voice
guidance prompts you to press {1} to
perform a specific operation, or press {2}
to listen to more available operations.
Operations are presented by voice
guidance in the following order:
– Play back all messages
– Play back new messages
– Record your message
– Erase all messages
– Record your greeting message
Note:
LIf you do not press any dial keys within
10 seconds after a voice guidance
prompt, the unit disconnects your call.
LIf less than 10 minutes of recording time
is available, the unit announces the
remaining recording time after the last
message is played back.
Remote commands
You can select the desired line(s) and
press dial keys to access certain
answering system functions without
waiting for the voice guidance to prompt
you.
1 Select the desired line(s) while you are
accessing the answering system if
necessary.
For line 1: {#}{1}
For line 2: {#}{2}
For line 1 and line 2: {#}{0}
LAfter selecting the line(s), memo
messages do not play.
2 Press the desired dial keys.
Key Remote command
{1} Repeat message (during
playback).*1
{2} Skip message (during
playback).
{4} Play new messages.
{5} Play all messages.
{9} Stop recording/
playback.*2
{0} Turn answering system
off.
{*}{4} Erase currently playing
message.
{*}{5} Erase all messages.
{#}{1}{7} Record a greeting
message for line 1 only.
{#}{2}{7} Record a greeting
message for line 2 only.
{#}{0}{7} Record a common
greeting message for both
line 1 and line 2.
{#}{1}{8} Turn answering system
on for line 1 only.
{#}{2}{8} Turn answering system
on for line 2 only.
{#}{0}{8} Turn answering system
on for both line 1 and line 2
*1 If pressed within the first 5 seconds of a
message, the previous message is
played.
*2 To resume operation, enter a remote
command within 15 seconds, or the
Turning on the answering system
remotely
If the answering system is off, you can turn
it on remotely by calling the selected line in
“Turning the answering system on” on
page 40.
1 Dial your phone number.
2 Let the phone ring 15 times.
LThe unit answers your call with the
greeting message.
LYou can hang up, or if you call from a
touch tone phone, you can enter your
remote code and begin remote
operation
Guru Guy
Ken Shepherd
  • 95 Answers
  • Posted on Oct 14, 2009
SOURCE: I HAVE PANASONIC MODEL NO. KX-FLB802. THE PROBLEM
In this order, press:
menu - # - 9000 - * - 550 - set - menu
then also:
menu - # - 459 - 1 - set - set - menu
Anonymous
  • 157 Answers
  • Posted on Feb 06, 2010
SOURCE: how do i record a answering message on my panasonic answering m/c
Hello jmkraus,
To record a greeting message on the Panasonic Panasonic KXTG1855.
(2 minutes and 30 seconds max.):
1 Press [OK]
2 Press up/down [^]/[V]: 'Answer System' : [>]
3 Press up/down [^]/[V]: 'Record Greeting' : [>]
Hold the handset about 8 inches away and speak clearly into the microphone.
4 Press [OK] to stop recording.
5 Press [OFF]
Here's the Panasonic KXTG1855 manual download link:
http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1855.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Anonymous
  • Posted on Dec 22, 2010
SOURCE: i had dial locked my
Hello me asking if I want to allow PIN Del Locke and thanks
Anonymous
  • Posted on Jan 07, 2011
SOURCE: How do I change my message on the phone. KX-T7665
dial 100 and select 5 for mailbox management
How to I change my outgoing message?
You can change your greeting message by pressing [MENU], [#], [3], [0], [2], press the down arrow to "Yes" press the select button. Then say your greeting and press [STOP].
Panasonic phone#KX-TG-63215 manual
You may download a copy of the KX-TG6321S manual at http://service.us.panasonic.com/OPERMANPDF/KXTG6311.PDF
Battery information is on page 6.
The KX-TGA630 handsets use two rechargeable AAA batteries, which should be available at just about any department, electronics, or office-supply store.
I HAVE A PANASONIC KXA144ES WHICH I HAVE INHERITED BUT NO MANUEL HOW DO I CHANGE THE VOICE MAIL OUTGOING MESSAGE TO MY OWN
You can download the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/KXTG5421S.PDF
2helpful
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
2helpful
Forgot how to record outgoing message on KX-TGA
KX-TGA 101S is the model number of the hand-set. Can you send me the model number of the answering machine? Also do you have the manual for both hand-set and answering machine? If not I can give you the link to download both manuals for free.
Master [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
I have a Panasonic multi talk phone 2 line phone, model KX-TGA270S. Somehow , it shows "ringer off line2" I can't find a way to remove this. What does it mean? Line 2 still rings
I have a Panasonic Multi-talk KX-TG2740 and I need to change the outgoing message. Anyone know how to do this? (There is no "greeting" button as mentioned below).
Thanks!
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
