Rowenta Effective DX1900 Iron with Auto Shut-off Logo
Posted on Jul 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red light keeps blinking and iron shuts off - Rowenta Effective DX1900 Iron with Auto Shut-off
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2798
Points
Rowenta DE8 will not stay. Plug it in, light comes on, little heat, light goes off. If I unplug,and replug about 4 times it will stay on and the iron works fine after that. Get tired of the unplug,replg routine every time we se the iron.
Anonymous
Level 2:
  • Expert 67 Answers
  • Posted on Aug 03, 2009
Anonymous
Expert
Level 2:
Answers
67
Questions
0
Helped
27924
Points
107
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Sep 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
5016
Points
8
No cable or loose connection- these units use a auto shutoff module that appears to be defective
Blinking red ready light
www.laundry.manualsonline.com has free manual
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 • Irons
Indicator button -red light blinks off and on
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
5helpful
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
6helpful
2answers
Blinking red light
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Sep 06, 2008 • Irons
Red Light Blinking
heatman101
1helpful
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Iron whuts off
check the circuit at the switch it could ave faulty cap that is not regulating the voltage properly.replace it.good luck
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
