Lots of ideas here. It is bound to be some type of thermal cut out. If the clothes are hot, it is the drum thermal cut out. If the clothes are only warm, it is the motor protecting itself from fire. When was the last time it was completely stripped and cleaned out?
Control Lock
Thank you for your question and I understand your concern. The "LOC" indicates the (Control Lock). This means the control panel has been locked and it will have to be unlocked before you can use the dryer. To unlock the control panel; press and release the Option and Select buttons at the same time.
The letters (LOC) indicates Controls are Locked. To avoid having someone accidentally start or stop the washer, press OPTIONS and SELECT at the same time until the Control (Control Lock) indicator is lighted. the controls, press OPTIONS and SELECT at the same time until the Control (Control Lock) indicator goes off.
Slot online sangat bermanfaat untuk memperoleh kemenangan hingga ratusan juta rupiah. silakan bergabungan bersama kami untuk keberuntungan anda di link ini. http://149.28.158.118/
8. Keylock This function allows to block unwanted changes of the set options on the bezel , during drying phase. Activation/Inactivation: Push 4 and 5 buttons simultaneously for two seconds . The sign "LOC" appears on the display. Unlocking the option, on the display appears the sign "Unl", only once. In case of opening of 'porthole' with activated key lock, the cycle stops but the lock is kept: to restart the cycle, you must remove the lock and restore Start. When the dryer is off, the option is automatically inactivated. Key lock can be modified at any time of the cycle.
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
