Um-hmm. Been there, done that! Hopefully, you have a manual (I'm not able to find one online).
Here are a couple of hints:
Remove all the thread from the machine.
Recommend using the colored threads that match the machine's guide--will help you figure out which thread is misbehaving.
ALWAYS RAISE the presser foot and thread each in the correct order! Check your manual, but most machines need to be threaded #3 (upper looper), #4 (lower looper), then the needles.
With each thread, grasp the thread below the thread tree and also below the tension disk and give a gentle tug. Sometimes the thread will pop when it seats in the tension unit.
The lower looper thread tail should drape OVER the top of the upper looper and thread, then sweep all threads toward the back of the machine and under the presser foot.
You might try contacting the Necchi Support service.
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
SOURCE: I need help to thread with diagram pfaff 5 threaded overlocker
Search the internet for:
Make + Model + the word "Manual" or "threading diagram"
or contact manufacturer support.
There may even be some videos on YouTube.
