Andy Nadolski Posted on Mar 22, 2018
Can I hook up Samsung 450 soundbar 2 Samsung 5500 Tower speakersif so how would I
1helpful
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
1helpful
I hook my ilive soundbar to my samsung tv and there no sound
Are you sure all conections are correct and power is on to sound bar
I connect my I live soundbar to my Samsung plasma TV and I'm not getting no sound from the TV to soundbar please help
Check the TV's audio menu to make sure there will be signal available at the RCA outputs
Some sets won't allow both internal & external speakers/sound bar to both be on.
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
How to remove sound bar AS501
There is a clip near hook by pushing it.It will unlock the bar and slide it to right in horizontal position but in tower position it will slide to left7_22_2012_10_18_04_pm.jpg
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
