Watches Logo
e
ernie goodvin Posted on Mar 22, 2018
Set time for 1063 watch - Watches
EZ-Repairs
Level 1:
Habit-Forming:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 22, 2018
EZ-Repairs
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
13
Questions
Helped
2313
Points
50
Skmei watch model 1063 instructions can be found at
Skmei watch instruction manual which include setting time and alarms.
Time not set properly in my watch lasika w-f62
To set the time on your Lasika W-F62 watch, please follow these steps:
  1. Press the mode button on your watch until you reach the time-setting mode.
  2. Press and hold the "Set" button until the hour digits flash.
  3. Use the "Adjust" button to set the correct hour.
  4. Press the "Set" button again to move to the minute digits, which will also be flashing.
  5. Use the "Adjust" button to set the correct minute.
  6. Press the "Set" button again to confirm the time and exit the setting mode.
If you have any trouble setting the time on your watch or if it doesn't seem to be working properly, please consult the instruction manual that came with your watch or contact the manufacturer for further assistance.
Feb 19, 2023 • Watches
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
How do you set the time on a watch with 4 buttons but no crown
Make and Model helps in questions like this.
4 Button Digital Watch
PDF4PRO https://pdf4pro.com > cdn > 4-button-digital-wa... PDF 4 Button Digital Watch. SETTING NORMAL TIME. • In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, ...
1 page
How to Set the Time and Date on a Digital Watch
wikiHow https://www.wikihow.com > ... > Jewelry > Watches
10 steps
1.
Read the labels on the 4 buttons on your watch. If you can't look up a manual right now, you can probably figure out how to change the time with some simple ...
2.
Press the "Mode" button or hold it down until the time flashes. The minutes or hours of most digital watches blink when you're in the time setting mode. On ...
3.
Use the "Start/Stop" button to change the individual numbers. Once you get the minutes or ho
Jul 22, 2022 • The Watches
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 • Watches
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
Hello, how i can set a time on addidas candy watch. it's late on one hour, we did try ev erything, but they still late. thank you
Thank you for contacting FixYa.
  1. Press the top button on the right-hand side of the watch to view time.
  2. Press the bottom button on the right-hand side of the watch and hold for two seconds.
  3. Press the top button on the right-hand side of the watch to choose a 12-hour setting or 24-hour setting. Stop when the desired format appears.
  4. Press the bottom button to change to time set mode.
  5. Press the top button until the desired time appears. Press the bottom button to exit time setting mode. The watch is now set.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Best regards. Jewel
5helpful
2answers
I accidentaly reset time & date on my square arnette watch and i need help to set it
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 • Watches
24helpful
Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
