Here is the user guide for the remote:
http://www.yamaha.com/yamahavgn/Documents/YEC/Other/RX-V567_Programing_remote_control_codes_for_TV_Control_Key_operations.pdf
SOURCE: need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
SOURCE: got new remote and it won't work with my receiver, don't know how to program it
You probably just need to set the remote address on the remote to that on the receiver.
Press menu twice on the front panel of the receiver and you should be able to see the remote address displayed. If not just press and hold the SAT button down on the upper left of the remote until all lights light up across the top and release. Now key in 0-1 and press the pound sign. The SAT button will flash three times and now press the record button. You should now be able to control your programming and receiver. Thanks for using Fix Ya. If you need further he; let me know.
SOURCE: dish 6.3 remote code for Samsung HT-X70 DVD/receiver
You will have to use the AUX button to program it to . Press AUX till lights light up then enter 4 digit code (if you have a 3 digit code use 1 as the first number) then press pund. And your good to go howevetr the only functions that may work is powere on an off.
SOURCE: How do I program an Echostar 5.4 IR to control a
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post recently and wanted to see if I could help. The best codes for the 5.4 IR remote are 500, 578, 514 and 758. I will also list here for you the instructions for addressing your DISH remote to your Sony TV. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to email directly at [email protected]. Thanks and have a great day!
Instructions for addressing remote to TV.
Note: The LED will flash three times.
SOURCE: How do you program a
Programming Without Remote Control Codes
