SOURCE: error message on recumbent bike
The problem might be the gearbox. I know because I have the same problem. Keys fitness is out of business, but "The Treadmill Doctor" has purchased the inventory of parts for the bikes. They will help you troubleshoot, and have parts available if you need them. The number is 1-888-340-0482. Or, you can go to treadmilldoctor.com.
SOURCE: schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays
"E3" error code
Check data cable integrity All wires in cable should be intact. If any
are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
SOURCE: PTS Turbo 1000 Recumbent Exercise bike
go to airfreetires.com and buy 27 x 1 1/4 Nu teck Savannah Cruiser (17-18)(630). cost 34 bucks plus s& h. there is info on that site about supplying 500 of these tires in the last 11 years to replace tires on this bike. they also speak incredibly highly of this bike as well. read blog. very interesting. this is a cult bike.
Testimonial: "PERFECT! This response is exactly what iI have been looking for. Many, many thanks."
