Kitchen Appliances - Others Logo
Linda Row Posted on Mar 20, 2018
Foodsaver V4880. The retractable handheld accessory stopped sealing. It goes through the cycle but doesn’t create a vaccum. The hose wasn’t retracting but that is solved.
5 Related Answers
Anonymous
  • Posted on Oct 25, 2008
SOURCE: Old vaccum retractable cord
This may come too late for you looking at the date of your posting. I have the same model and it stumped me for a bit too but I did get it open. It's real easy once you know how. Open up the front and remove the bag, then look at the side (beige) bumper strip that runs from front to back. This is splined. You can see it by looking carefully at the front. The brown case is held together by the splined rubber strip. Simply use a pair of slip joint pliers or a vice grip. Grab it and pull to the front. It took a bit to get it moving but then it slid right out. I found it easiest to place the vacuum on the floor, hold it with my feet and with the front open and the bag out I just grabbed the side strip with my pliers and pulled hard and it slid right out.
Good Luck.
Anonymous
  • Posted on Feb 20, 2009
SOURCE: foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Anonymous
  • 3 Answers
  • Posted on Apr 03, 2009
SOURCE: my grohe kitchen faucet hose won't retract
the first thing you need to check is the weight on the hose under your sink. if it is set too high or to low it doesnt allow the proper weight to pull the hose back into position. also check to see if the hose is twisted under your sink also. I hope these answers will help you out.
Anonymous
  • 11 Answers
  • Posted on Jun 25, 2009
SOURCE: Tillia Foodsaver VAC 370 won't stop vaccuming to seal
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
snap101
snap101
  • 117 Answers
  • Posted on Aug 01, 2009
SOURCE: grohe sprayer faucet will not retract, spring around hose below.
check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
How to stop Aqua System retractable hose reel from leaking from the bottom?
Question edited for clarity and spelling 'retractable'.
The only way is to open it up and find where the leak is, but it is likely the connector to the Leader hose.
It appears to be Australian. I have the Amazon Aquazilla, and can recommend it.
https://www.google.com/search?q=aqua+system+retractable+hose+reel+leaking+water
Oct 11, 2023 • Aqua Garden
2answers
Foodsaver repair
Sorry to laugh, but that is too funny!
These retractable cords are very difficult to get back in order. You would be better off just closing up the sealer and allow the cord to remain extended. You could spend hours rewinding the cord and setting the tension spring when it pops open and makes you a crazy person.
Holman retractable hose reel won't retract garden
The Booklet says "if the hose retraction wheel is stuck and the hose is fully extended, the wheel still have movement. Grip the hose close to the guide hole and gently pull.
The retraction wheel will give you enough movement to unlock itself before you slowly allow the auto retraction wheel to wind the hose back into the unit."
They also say when walking the hose back to the unit, turn the tap off and press the lever on the watering gun to release pressure on the hose. This makes the retraction to the hose reel a lot easier and prolongs the life of your hose reel.
More: Hose Reels
My d51238 brad nailer is not retracting nails after the first time
Driver not retracting is caused by bent shaft, oring too tight/loose, check seal missing, or lower bumper cracked/missing pieces. With air hose removed, push driver all the way up with thin metal. Should be rather easy to move. If hard to push, remove head and pull driver to check for items mentioned above. If easy to push up, test gun. If driver stays all the way down, pull cylinder and make sure check seal is in place. If driver goes partially up, oring too tight/loose, lube piston seal with white grease or silicone paste and retest (if bent, adjust or replace). Good luck
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
1helpful
5helpful
3answers
Saturn sl2 emissin problem
If the SES light is on, take a paper clip bend it in a u-shape and jump the scanner input positions A B. This should flash the ses in sequesces to give you the trouble code, Please see the following link. http://www.troublecodes.net/GM/ Refer to the code to see what the issue may be. SES lit means that there is a emmissions related issue. Refer to the other links for additonal information on O2 sensor resistance, and the egr valve solinoid. Check the EGR is relitive easy for operation. Remove the vaccum hose and place a hose of similar suckon the hose to pull vaccum if the diafram underneith retracts, hold the vaccum by plugging off the tube with your touge if the diafram retracts, will not hold the vaccum, it is bad. The solinoid should read 40-60 ohms if good. http://www.saturnfans.com/forums/index.php http://www.aldlcable.com/sc/pages.asp?pageid=21
http://www.saturnfans.com/forums/showthread.php?t=37884
Top FoodSaver Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
