SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
SOURCE: refilling ink cartridges for epson printer CX6000
You can purchase re-manufactured cartridges online from Re-Inks and Atlantic Inkjet. This is usually the easiest way to get them, if you refill them your self they have a better chance of leaking and ruining your printer.
SOURCE: refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
SOURCE: the ink cartridge cannot recognized (refilled 3 times)
i am having canon pixma ip1300 inkjet printer. it worked properly till 13th april 09 i got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to make my printer work again. give me the remedy as quickly as possible Thank you
SOURCE: How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
