LG Rebel 2 LTE
"look for mask kind of symbol and remove it.. That's it" I did not find it
Trang ch Thit Gym Vit Sa cha my chy uy tn ton quc
Notification bar --> Safe Mode on --> Safe Mode off
Progress through the steps with screen taps.
SOURCE: need to cancel add-ons for an LG neon 2
Sorry, I don't have any experience with LG outside the KC910 however, you can generally remove programs and add-ons the same way you would on a computer. Find the file containing it then delete it. You may have to turn your phone off and then on to have this completed.
In a worst case scenario, you may have to do a factory reset. Just make sure that you don't have the unwanted programs on a removable memory card which will allow it to reload after you do this.
To do this enter 3845#*370# and select factory reset from the list. Should be about the 4th one down. If you have other than the GW370 model, just substitute your model number for the 370 in the code.
Hope this helps.
SOURCE: How to use a verizon 4G LTE phne with another carrier
You probably cannot. Most phones need to be unlocked, which is a whole different can of worms. And probably this one will not work in the 4G mode with another carrier.
SOURCE: I have a LG android phone through sprint. In the
I had the same problem with my lg optimus l3. first do phone switch off & switch on again. if safe mode displayed again, you have to remind the installed app or game before display "safe mode" at first time. then uninstall the app. then your problem will be ok
SOURCE: how to get my android phone off of safe mode
Safe mode is an option of the Factory mode in Android devices along with other options. The option can be activated or enabled automatically when the device encounters unsafe conditions. The Safe mode can be disabled manually by first entering the phone's Factory mode by first switching the phone off and restarting it by pressing the Power and Volume + buttons simultaneously long enough for Factory mode menu to appear. Select Reboot from the menu to restart phone.
SOURCE: how do I disable incognito mode on my lg android phone
I can say I used to be like this, but do not know how to resolve, have to find a technician, to be repaired.
https://muaban-canho.com/https://muaban-canho.com/
