SOURCE: super multi dvd writer gsa-h55n
Well, since I received a solution from MAXTRIXKHAN, I just wanted to check back with NCIX.com, and here is a recap of what I did, and what they told me...
After a few tries, I had to contact LG Customer service.
I tried to burn to...
-Maxell CD-R, no problems,
-TDK DVD-RW, no problems,
-Verbatim DVD+R, Computer hangs.
Well, I bought this DVD-Writer to replace my old GSA-4167B, and LG customer service told me that this DVD-Writer does not support the Verbatim DVDs.
So, if you have plenty of Verbatim DVDs, you should forget about this writer.
Supported DVDs...
Maxell, Sony, TDK
Will have to send it back to NCIX
So beware
tiyo73
SOURCE: LG GH22 dvd writer - not reading
I had the same problem with the GH22 Internal drive on vista. Assuming this is the only cd drive you have, just go to the device manager and remove/uninstall anything under "DVD/CD Rom Drives" then restart. It should get picked up and recognized properly. It took a couple of restarts to work. For refrence, I only have the LG GH22NP20 installed, what appears in device manager are 2 items... (1)HL-DT-ST DVD-RAM GH22NP20 SCSI CdRom Device... (2) KU1051Q EAG855E SCSI CdRom Device... Incase you have multiple cd drives, this should help tell em appart. Enjoy. IDK399
SOURCE: HELP!!!!! : "Not found CD/DVD Writer driver"
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
http://support.microsoft.com/kb/314060
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment. If this information was helpful, please take a moment to rate the solution. Thank you
Testimonial: "thanx"
SOURCE: CAN NOT READ SONY DVD-RW 1.4 GB DISK FROM COMPUTER DVD WRITER
your dvd has scratches on it. See if it is visible then it can not be repaired
