Question about Dometic Rooftop RV Air Conditioner
Installing a new replacement Bi-metal 6 wire thermostat in my RV?Dometic AC 70219968 ducted
Dometic 3313477.000 thermostat has 6 places to attach wires labeled- RC, G, Y, W, RH, and H.The 6 wires coming through wall are 2 thick wires-1 red,1 black,4 thin wires-1red,1green,1white and 1blue This RV also has a suburan gas furnace that this thermoatat controlls. Found answer if anyone has same problem?Thick red and thick black both go to furnice thick red is common and goes to W ,Thick Black hot goes RH , Thin 4 wires: white is compreesior goes to Y, green wire is high fan and goes to G , small red is hot and goes to R , blue wire is low fan and goes to H I hope this helps anyone out there having same problem?
SOURCE:
tripletauto
  • 1450 Answers
SOURCE: what cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Posted on Sep 23, 2008
  • 61 Answers
SOURCE: how to hard wire 240 volt wall heater
Black is 120v hot
Red is 120v hot
Black and Red go to opposite legs to get 240v between them.
White is 0v neutral
copper is Ground
Posted on Jan 02, 2009
  • 24 Answers
SOURCE: Need help with wiring thermostat
first do you have a heat pump unit or standard a/c? standard a/c connections at the thermostat go like this red wire to rh-rc which is the 24v power and you don't have to remove the jumper.white goes to w which is the heating wire yellow goes to y which is the cooling wire green goes to g which is the fan wire and blue goes to c which is the common wire. so if your stat has rc- rh ywgc you should be set if the wires on the furnace correspond with the same alpha designation.orange may be used if u have a heat pump unit otherwise it may just be a spare you cap off and leave behind the subplate.
Posted on May 31, 2009
  • 5013 Answers
SOURCE: I have a 1998 ford fiesta and I am trying to
Is this website of any use?
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Posted on Sep 11, 2009
  • 108 Answers
SOURCE: Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Posted on Nov 01, 2009
All is standard, heater is gas, AC is electric, old thermostat was old and burned. I have TH3110D1008 and 4 wires.
the colors on standard t-stat are rh/rc gets red wire. g goes to fan green. y goes to outside unit cool. and in your case w labeled black goes to heat normally this wire is white.
Jul 25, 2015 | Heating & Cooling
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
Hi, I just bought a Honeywell RTH8580WF1007 and tried to install it, I placed the wires in on the same letters as they were with my old thermostat. However, now that the new thermostat is wired up, it wont...
739dfb58-7a38-4a51-a7ed-ab942a7253a0.pngRH is red heat and RC is red cool, red being the "hot leg" of the 24 volt control voltage, normally you will have a jumper from RH to RC, the fact there is an RC tells me there must be an RH too?
I will look after this post and come back if any new info was found, other wise I will say call 1800 Honeywell and provide you a diagram to check out.
Aug 25, 2013 | Honeywell RTH8580WF1007 7Day Touch...
HOW CAN I TELL WHICH RED WIRE IS RC AND WHICH IS RH? THE WIRES COMING FROM MY WALL ARE NOT LABELED AND ARE THE COLORS 2 WHITES 2 REDS AND 1BLUE
This is a fairly hard question to answer. Evidently someone has run two sets of wires to your thermostat. One set has three wires in it: red, blue and white. The other set has two wires in it: red and white. One or maybe both red wires is the rc and rh wire. RC and RH actually wire together with a jumper wire. The RC and RH wire is usually the red wire that goes to the "R" on you furnace circuit board. If you can find out which red wire goes to "R" on your furnace circuit board you will solve the problem.
May 10, 2011 | Heating & Cooling
I purchased a rth2310b and connected the red wire to the RC and white to w the green to g. It still will not start furnace. This is a gas forced air.
I think there is connection labeled Rh. The reason for having Rc and Rh is that some units have a transformer for the heating unit and seperate on for the cooling unit. If you only have 1 transformer then they have a jumper between Rc & Rh. Rh being for heating and Rc for cooling. Hope this helps. Let me know what you find.
Aug 09, 2010 | Honeywell Programmable Thermostat Heater
Nov 01, 2009 | Honeywell Electronic Programmable...
I just bought a repo house and there is no identification on the wires coming out of the wall for the thermostat. I have a red, green, white, and blue wire coming out of the wall. I need to know where to...
The best way is to see where the wires are connected at the furnace and duplicate them at the thermostat but typically the connections are:
Red wire to "RC and RH"
White wire to "W" (for heating)
Blue wire to "Y" (if you have central air)
Green wire to "G" (this is for the furnace blower)
Aug 27, 2009 | Hunter Fan Company 5/1/1 Programmable...
I'm trying to install a Honeywell RTH2310B programmable thermostat. I only have 3 wires coming out of the existing thermostat (the red wire was attached to both Rc and Rh terminals). The other wires were...
Your house might be older.  Are your receptacles two-prong, or three?
I would ignore the missing "G" wire, and connect Red to both Rc and Rh, and Y to Y, and W to W.
Jan 01, 2009 | Honeywell Focus 6300B 5-2 Days...
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dometic Rooftop RV Air Conditioner Logo
559 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
