Question about Frigidaire Kitchen Ranges
I have a Frigidaire range LFGF30532FA. The top works but not the oven. Why?thanks
I have never been able to make oven work. Manged to oen oven door even though a F90 code.
SOURCE:
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
jyackle5
  • 8197 Answers
SOURCE: oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Posted on Dec 16, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
SOURCE: Frigidaire Range FEF357BBD error code F9
I had the situation where the oven thinks the door is locked but it was not locked. Setting and holding clear eventually gave a f9 error.
I solved this by turning the circuit breaker off and taping over the oven light switch ( so it thinks it really is locked ) and turning on the breaker. The oven unlocked and appears fine now.
Posted on Jul 09, 2010
Where are the relays that controls the oven on frigidaire electric range located
if range is self clean make sure door is closed, put on self clean wait about 0ne minute or so then cancel self clean . sounds like range is stuck in door lock Cheers
Dec 11, 2013 | Frigidaire FEF366 Electric Kitchen Range
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 04, 2010 | Frigidaire FGF316 Gas Kitchen Range
Compact 30 Frigidaire Model rbe539n range/oven. I am looking for the switch to turn on oven light.
Be sure the timer (right most knob) is set back to MAN (manual) after cleaning in order for the oven to work.
Jan 14, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Oct 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire ES340 clicking noise and display blinking when oven door opens
sounds like a bad door/light switch.it cant seem to tell if door is open -closed and clicking really fast betweeen the 2. replace the switch
Mar 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Need help with error code for Frigidaire Oven Please!
Hi thanks for the question. the code f 2 means the oven sensor has failed .the sensor is located in the oven, top left corner. replace the sensor. thanks the appliance doc.
Jan 12, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
