There's this website www.reliable-store.com
They have books on ALL vehicles.
it covers wiring diagrams, electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
SOURCE: 1994 toyota 22re 4x4 pickup fuel injector wiring diagram
the color of the plastic plug does not matter... You will have two injector plugs with white/red and yellow wires - those two go to cyl#'s 1 and 3.
the other two plugs will have white and blur wires.. those two plugs go to injectors # 2 and 4.
SOURCE: i need a diagram of the vacuum hoses for 1994 toyota 22re.
if there is an library near you there you can get a diagam of how they should go and if not if there is a place were you can get a fax you could call a toyota dealer in the part department and they could fax them to you.
SOURCE: pinout ecu toyota 22re 1989 p/up
this should do the trick
http://media.photobucket.com/image/1989%20toyota%20pickup%20ecu%20pinout/4runnerchevy/other%20conversion%20stuff/ecupinoutdiagram.jpg
SOURCE: i replace my fuel tank on a 1981 Honda civic
Below is the fuel tank diagram including the sending unit where the fuel lines connect:
