SOURCE: The picture on screen is upside down
Jay there should be a External Switch on the Screen,Try looking ttech
SOURCE: monitor displays everything upside down
On the monitor thereshould be some buttons, like menu a let arrowa right arrow etc. Simply press menu and look for the screen rotation setting(many monitors are different and it might take some fiddling around to actually find it) and then set it to the setting you want. There is aslo a reset option, you can use that if you choose and this will restore it to the defaults..
SOURCE: My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
SOURCE: picture is upside down
Go into the menu, select "Settings", then "System" and then uncheck the "Ceiling" mode. The image will flip around instantly.
