Question about Hotpoint Dryers
Hotpoint dryer stopped working. Is there a reset button?
  • Jean DeLauche
    Jean DeLauche Mar 17, 2018
    Hello - What is the model number of your Hotpoint dryer? I want to help you with your question, but I need more information from you. Please add details in the comment box.
    Note: One thing which may have caused your dryer to stop is that it is clogged with lint. Check the lint filter for your dryer and remove all the lint there. Plus, check the dryer vent (at the back and possibly the bottom) of the dryer.) This YouTube video may prove instructive:
    https://www.youtube.com/watch?v=mi9MsDC-...\\
    Also, watch this YouTube video:
    https://www.youtube.com/watch?v=xK0f2dUM...
    Best wishes.
  • Hotpoint Master
  • 2,484 Answers
No, check for broken drive belt.
Posted on Mar 17, 2018
2 Suggested Answers
SOURCE:
woodchuck789
  • 4070 Answers
SOURCE: Hotpoint side by side water button does not
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
Posted on Aug 09, 2009
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
WERE IS THE RESET BUTTON ON HOTPOINT DRYER CDT 80
Not sure if all dryers have a thermostat reset. You can check your model (which might be CTD80 and not CDT80). Usually it can be reset if there is a small hole in the middle of the device where you can insert a tooth pick and press it.
Location of thermostats is at the back. Make sure the power chord is unplugged from the wall.
See this youtube video.
how to replace Hotpoint tumble dryer thermostat
Sep 01, 2014 | Hotpoint Dryers
Do a tumble dryer have a reset button once you have changed the thermostats?
check the heating element they might be the problem if they are not getting any power or are open.
Aug 27, 2014 | Hotpoint Dryers
Hotpoint tumble dryer heating coil not working
You reset it by disconnecting the power to the dryer.
Jul 10, 2012 | Dryers
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Dec 08, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
139 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
