The simple fix is stop playing with the side buttons and buy a new remote for $24 :>D If you really like playing with the side buttons, open the set up and spray the contacts behind the buttons with Switch Cleaner (NOT WD40).
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Please tell about your phone make! Pl try with Master Reset mobile. After
performing this process my mobile's camera is working fine now. Just
use following steps.
First unlock your mobile -> now type *2767*3855# -> now wait for
few minutes until this process complete -> after this process you
will not get any problem.
Note: 1. Solution for samsung 2. Take backup of your mobile before performing this process.
Hi, - To unlock you samsung gt c 3530 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password. - The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Press YSTEM SETTINGS button. On screen KEY OP PROG > enter code (00000 default) > NETWORK SETTINGS > INTERFACE > IP SETTINGS. Ensure DHCP is deselected ( touch the tick box to remove tick mark) and enter IP details. Select OK and then press CA button. Reboot machine for settings to take effect.
