SOURCE: kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
SOURCE: F11 code on my kenmore range. The repair says the
No. Other than order the part from Sears.com and install it yourself.
SOURCE: F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
SOURCE: Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
What is the complete model number of your unit?
1. (F11, 12 & 13)
Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If
fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
