Dishwashers Logo
S
Sandy Crawford Posted on Mar 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool dishwasher WDF530PLYB and I need to clean my filtration screens and I can't get it out. Please help. Thanks
Jim Goldsmith
Level 3:
  • Whirlpool Master 2,005 Answers
  • Posted on Mar 17, 2018
Jim Goldsmith
Whirlpool Master
Level 3:
Answers
2005
Questions
Helped
736973
Points
6152
If you are speaking about the filter behind the spray arm in the tub:
grasp the tower (the top post above the spray arm)
and unscrew it. CCW under and in the center of the tower hole thus revealed is a philips screw and fiber washer holding the spray arm on remove these then remove the arm. next, using a flat screwdriver un-snap the filter cover
1 Related Answer
Anonymous
  • 58 Answers
  • Posted on Mar 09, 2010
SOURCE: Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Dishes not clean. Glasses have a film on them. even on the long cycles dishes don't come clean. Did add salt and rinse solution which helped a little.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
I have a whirlpool dishwasher that is not working properly. It is less han 3 years old. It is not cleaning the dishes properly and leaving a heavy film on the dishes which only came off by handwashing with...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info. You will love the results!
I have model DU810SWPU3 Whirlpool dishwasher that is 1 yr old. Plastic dishes appear to have a film on them when cycle is complete. The water also seems to drain slowly. I assume that what appears to be...
We're having same problem with our whirlpool GOld quiet partner III. We moved into our house three years ago and no manueal was left. I am sure its a filter or plug but I can't seem to figure out how to...
Mar 09, 2010 • Dishwashers
4helpful
2answers
The top rack does not get clean. There is a dirty
Most likely the "food grinder" screen is clogged, which limits the flow throught the pump, leaving thehigher dishes unwashed. It's flaw inthe design of whirlpool/kitchenaides. Not only does the screen clog but the teeth on the "grinder" wear down, the girneder does no grinding, and the food particles build up onthe screen, clogging the water flow. Open up the collector, pul out he choer/grinder and clean the screen. Check the teeth on it and if worn, repalce the chopper/grinder. If it happens again , then the choper/grinder driving mechanism is basd -- replace the pump/motor assembly.
It's not cleaning the dishes. Sounds fine, but
Whirlpool dishwasher doesn't clean very well
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
2answers
Dishes seem to have a dirty water film on them
is this connected to another appliance or is it under a sink connection?
Whirpool dishwasher gold quiet partner 3 is leaving a heavy film and waste on dishes is there a filter to be cleaned?
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
