J
John Higney Posted on Mar 16, 2018
Region code for Samsung HT 4500 - Samsung Audio Players & Recorders
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Nov 04, 2008
SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems. Swapnil
KOL_Inc
  • Posted on Dec 02, 2008
SOURCE: region codes
While looking through some forum posts i found the way to fix the problem. It takes a bit of fiddling around but it does work... I tried it out last night.
Firstly you need to put a DVD of a different region into your player and wait for it to start to read the DVD before you commence the procedure... it takes a bit to get the timing right.
when the DVD can't be read it, on screen Eject Disc will come up
Press Repeat & Hold 3 Seconds (it may work using either repeat button on the bottom, i tried both.
Press 76884
After entering those 5 digits, you should see a number in the top left corner of the screen corresponding to the current region (4 being Australia region)
Press 9 for "auto-region" mode ie. Region Free
Turn Off Machine
and there you have it. The timing is crucial so start trying as soon as the DVD is in. It took me 5 goes before it worked.
You will notice that it may take a bit longer for the other Region DVDs to be read then normal but it's only a few seconds longer.
Anonymous
  • Posted on Jan 11, 2009
SOURCE: Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
Anonymous
  • 5 Answers
  • Posted on Feb 05, 2009
SOURCE: region codes for Samsung ht z110
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
posted by alfredsaviou
Anonymous
  • Posted on Mar 22, 2009
SOURCE: region free code for samsung HD-BD2E
Haven't tried it, but found this online somewhere....
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9.
7. Press ENTER on remote. (The tray will open)
8. Switch off power from remote, then switch back on.
9. Player is now Region Free.
3answers
I would like to make my SAMSUNG HT-F5500W region free
There seems to be useful info here:
http://forum.videohelp.com/threads/342271-Samsung-HT-D6750w-Region-Free
Samsung ht-d4500 region code
I just leave this message to tell you that this really worked for my blue ray samsung ht-f4500/zx in Mexico City. Thank you very very much. Cheers
Removal of region codes
PRESS KEY " ENTER 84269 ENTER "
6helpful
Region codes for Samsung ht z110
Try this
19helpful
2answers
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
