SOURCE: I have an old Mitutoyo
Precision Tool Works(www.precisiontoolworks.com) will sell replacement probes(AKA detectors), They can also sometimes repair or rebuild old probes. 1 877 304 4789
SOURCE: I have replaced my remote
1) Try resetting the code search / programming
2) Try quickly tapping the OFF command key (opposed to holding it down for 2+ seconds)
3) Be sure there are fresh batteries in remote
The remote could possibly transmit a lower frequency setting for the 'OFF' state than it does for the 'ON' state. See if there's a setting for ON/OFF commands on the remotes 'Settings Menu'. You can also check the owners manua for your universal remote,l under 'POWER options ON/OFF. Make sure nothings blocking the IR sensor on the TV. Also bare in mind it may not be the remote but rather the TV's IR sensor.
However,
If still no results then send it back and obtain the original remote for the TV, which is always the best option.
http://tvtechwork.webs.com/
SOURCE: Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
SOURCE: How do I reset a Mitutoyo SJ-210 surface tester. I get a returning error.
Question edited to add maker.
Question moved from Office Equipment to Mitutoyo.
See the link
https://www.google.com/search?q=RESET+SJ-210+SURFACE+TESTER
