Question about Yes Televison & Video
When i use the remote and try to get the menue screen it won't show. How do i get it back? Yes the other buttons work but not the home menu button
SOURCE:
Bajanguru
  • 7752 Answers
SOURCE: SE K850i menu touch screen button not working properly
you need to have the phone service you need to take the phones in and have them check.
Posted on Jun 20, 2008
Neoklassic1
  • 70 Answers
SOURCE: The menu button on my remote doesn't work
Try replacing batteries. If that doesnt work try aiming directly at Receiver's sensor. If all the other functions work except the menu see if you can access menu directly from the unit itself. If it works then you might need to replace the remote
Posted on Oct 13, 2008
Geekman
  • 32281 Answers
SOURCE: nikon coolpix 774 menu buttons don't work
Try resetting the camera back to the factory default setting.
Remove the battery, leave it for 1/2 + hour, insert the battery and configure date time etc.
If it doesn't work then you have faulty camera.
Posted on Dec 03, 2008
  • 304 Answers
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Posted on Jul 17, 2009
SOURCE: my iphone home button not working
May be the flex cable that connects the home button to the motherboard is damaged. This part is cheap and easy to install.
You can find a replacement here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Posted on Aug 19, 2009
Why my coby mid8065 stop working i try the reset button but still nothing happen, it show the coby logo and the android but didn't go far.
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 08, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 12, 2012 | RCA RCR312W Remote Control
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Jun 28, 2012 | Televison & Video
I nedd to unlock my fpa on my RCA flat screen model 20V500T
Jun 26, 2012 | RCA Televison & Video
What is emergency calls
YES you can unlock it yourself but unfortunately you will have to reset it and lose all your apps/pics etc.
1. switch off. Hold volume UP and power button and home button simultaneously. release home button (and press again) while still holding volume up and power button. A boot up screen will pop up. Use volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked. Get another phone to call your phone. as soon as you swipe answer press back key (arrow key) (you gotta be quick) and the main home screen will come up!!! . press the left menu button and select settings and turn off pattern code then go to menu and factory reset the phone again.
It worked for me ,.. hope it works for you too
Apr 17, 2012 | Samsung Galaxy Y
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
How to unlock the MENU button on my TEAC RC-1058 remote control
Yes I know press timer and it will take u into the menu........
Jul 31, 2010 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
My wii cant connect the 2nd remote at the opening screen why?
Yes, when you're at the menu, click the home button, at the bottom it should say something like "Wii Remote settings," click it. Now click "Reconnect," hold down 1-2 buttons simultaneously on all the remotes you wish to connect. If they won't connect, then you need to sync them, behind the battery cover on the back of every remote is a little red button, hold it down while holding down the red sync button on the wii, located next to SD card slot. Then try connecting again.
Hope this helps!
Aug 26, 2009 | Nintendo Wii Console
Can't use menu function on remote control for pioneer krl-32v TV
ok try this first, remove the batteries from the remote and yes make sure you replace them with brand new ones, but before you do that unplug the tv from it's power source and let it sit for a couple minutes at least 3, then plug it back in , put the batteries back in the remote and see if you have everything back, if not I would return everything since you said you had just purchased this set, or contact the makers web site and see if they will provide a new remote since taking the tv back is a real pain.
Mar 14, 2009 | Electronics - Others
Televison & Video Logo
27 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
