The arrows show which way the connecting pin comes out. You need a pin press. Take it to a local jeweller.
https://www.amazon.ca/Watch-Band-Tool-Kit-Grey/dp/B087N7FGZJ/ref=asc_df_B087N7FGZJ/?
Flip the watch band over and check the underside. Links that can be removed will have an arrow etched on them. The arrow's direction indicates which way to push the pin to slide it out of the link.
Watch Bracelet Link Removal Tool - Stauer
SOURCE: shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
SOURCE: Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: How do I shorten watch bracelet?
You may have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
hammer!!!
twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY
bracelet.
Job done!
SOURCE: Relic watchband that isn't the same as instuction book
You may or may not have
out.
hammer!!!
twisting.
bracelet.
Job done!
SOURCE: How do I shorten the watchband to fit my wrist?
If you turn the band inside out...and stretch it...you will see either 2 or 4 small tabs per section. Use a jewelers screwdriver to lift up each tab per section and slide that section out. Now it will be easy to take other sections out as you won't have to maintain pressure on the band. Reassembly is reverse order.
Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
Best regards. Jewel
