Question about Deni Crock Pots & Slow Cookers
I need to replace the sealing ring/gasket for a Deni 9700 pressure cooker. I've read that Deni is out-of-business.
    Top Expert:
  • Deni Master
  • 53,176 Answers
Fixya is unable to suggest sources of Deni parts.
Posted on Mar 14, 2018
SOURCE:
robotek
  • 1512 Answers
SOURCE: I need a new gasket
Hi, if you give me the details of your location(country) I can help you out.. Waiting for your word. :)
regards
robotek
Posted on May 05, 2008
SOURCE: need a new rubber seal for the lid
Need to have new rubber installed on my pressure cooker lid, but cannot find anyone to do it. Presto says they do not do the labor but will send me the rubber???? Any suggestions?
Posted on Dec 09, 2009
micromatikal
  • 2777 Answers
SOURCE: I need a gasket for
Ok no problem, are you in the USA or the UK? They are known for being a UK brand so want to make sure.
Thanks
Tim
Posted on Oct 08, 2010
  • 1739 Answers
SOURCE: I HAVE A WOLFGANG PUCK
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
Not sure if your model is the BPCR0175 but gaskets are available on-line for the models shown; you may want to confirm compatibilty with their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Posted on Apr 01, 2011
  • 1739 Answers
SOURCE: Looking for place to order replacement Seal Ring
Replacement parts for the Wolfgang Puck pressure cookers are available here:
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
Sorry someone has not responded sonner.
FAGOR LUX 8 QUART MULTICOOKER:
The Floating mini gasket is a silicon ring that is placed on the floating valve, a metal piece located in the lid is it missing or damaged in some way preventing the lock
Mar 07, 2018 | Crock Pots & Slow Cookers
Try to find a sealing gasket for WP 8 quart pressure cooker.
cook ware shops
seal and "O" ring retailers
e-bay
manufacturer spares
Dec 02, 2017 | Crock Pots & Slow Cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Rubber taste and smell from pressure cooker gasket
Is this genuine factory replacement or some aftermarket part? (from China)
Nov 29, 2013 | Crock Pots & Slow Cookers
I can't get my 17quart pressure cooker to seal. I was looking for an online manuel so i could find out why.
Take the rubber ring out of the lid.
Wash it with warm soapy water.
Dry it.
Oil it with vegetable oil.
Now do you see how the rubber ring has a groove around it on the inside? Push your thumb into the groove and work it around the ring, you're trying to spread the rubber V out.
Put it back in the lid and take it for a test run.
In the future store your cooker with the lid upside down on top, keeping it closed will ruin the seal.
If it still won't seal replace the rubber parts, you can get a kit for your cooker from presto.
Regards
TickMagnet.
Aug 08, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
Crock Pots & Slow Cookers Logo
123 people viewed this question
Top Deni Crock Pots & Slow Cookers Experts
tsalagi152
ellenskitche
Irene Tulloch
Are you a Deni Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
