Pool & Spa Logo
Joe Prescott Posted on Mar 14, 2018
Pool vac keeps getting stuck in a corner and wont move the rest of the day
gene mattice
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Mar 14, 2018
gene mattice
Contributor
Level 1:
Welcome Back:
Answers
Questions
Helped
1126
Points
Pool vacs sometimes do that. I changed my pump to the next bigger pump because once you hook that vac to it, it reduces the flow rate. the lesser flow rate doesn't seem to be enough to move the vac around and gets stuck easily. Also when the vac starts getting full it reduces the flow rate and will get stuck. Good luck.
1 Related Answer
Anonymous
  • 46 Answers
  • Posted on May 26, 2009
SOURCE: Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
Pool sweeper gets stuck on walls
Thanks for the apology. Cars and Trucks is the default category. I moved it to a better one.
Usually questions can be answered by Google. Generally if you have found an issue, then others will have as well and will have posted the solution. There are also pool companies that have forums where customers can post questions and someone at the store answers. Normally, I will find the answer for you but you didn't post the two most important words, 'make and model'.
Try Googling
make model getting stuck
and to see what makes it all work
make model manual
and make model parts schematic
There is a LOAD of information in this link and suggests you have to adjust the water flow and suction.
https://www.google.com/search?q=Pool+sweeper+gets+stuck
2answers
Jet vac will not move around the pool
Does pump work?
if not, then it's a pump problem.
If yes, then possibly plugged with debris either in the booster pump impeller or at the finger screen?
It's located at the wall adaptor.
Or... The internal gear assembly is the problem?
Sometimes the get stuck, broken tooth on an individual gear, or foreign debris clogging it.
Keeps getting stuck in corners
There are several things that you can try if your pool cleaners getting stuck at corners. First, make sure that the cleaner is getting the proper water flow and adjust it if necessary. Also, make sure that you inlets are adjusted so that they are pointed down and at the center of the pool. This will ensure that the cleaner is pointing in the right direction. Check your hose weights to make sure that they are correct. You will know they are right if the cleaner is sitting at a 45 degree angle with the pool's bottom when resting.
My zodiac baracuda gets caught up in the corners of my pool constantly. What should I do?
If these pool cleaners are getting stuck on corners or other obstacles, try these solutions. Try using Pool Pulse to lower the flow. If you are getting too much flow, the cleaner will stay along the edges of the pool and in corners. You might also need to adjust hose weights. You can adjust your return flow lines in the pool. If they are directed toward the corners, try moving them down and center to direct the cleaner in the correct positions in the pool.
2answers
Stuck in corner
Try adjusting your returns to change the currents in the pool and see if that helps.
Why do I have air in my system after manual vacuuming?
you need to get all air out of 'vac' pipe before starting to 'vac'.
Best way is to start with 'vac' end - place in pool and push to bottom - let rest of hose follow - keeping hose under water (as much as possible )
** sorry if you are doing this all-ready.
No reverse
The gear placement is irrelevant. Is the propeller binding up? Also check for debris in the reverse jets. The beauty of the Jet Vac is it's simplicity,
2helpful
Top Pool Vac Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool Vac Pool and Spa Expert? Answer questions, earn points and help others
