SOURCE: Changing TIME on Nortel I2004 phone.
This should be changed from PBX side and not from Phone.
SOURCE: time on phone
Programming should be done from the M7310, M7324 or the T7316E set.
Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modulur 0x32 control unit wish will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the (next) button until you see what you want to change. Then press (show),then (change) if you want to change it. If you pass it, just press (back)
Example: To change the Time & Date Press (next) until you see Time & Date. Then (show) Then (change) Then (change) again, change it if you need to, Then (next) again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press (next) until you come to the (Hour). Then Change it. Then press release (RLs) when your done.
To get out of programming, just press the release button (RLs).
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password
Retry
Step 2
Press 266344
on the dial pad buttons to enter the DEFAULT password. Your password
MAY BE DIFFERENT! The display will show the following options:
Hour: 01
Next
Change
Step 3
Select CHANGE - the display will show the following options:
Hour: __
Cancl
Step 4
Use the dial pad buttons to enter the hour. You must use two digits for
all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM
or PM. Select CHANGE and OK to choose PM.
AM
OK
Change
Step 5
After you have entered the hours, select NEXT. The display will show
minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the
RELEASE (RLS) button to end your session. The time will be changed and
the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00
Next
Change
Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99
Next
Change
Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
SOURCE: Change Time
THe older norstar systems you had to go into programming to change time and on the newer systems press feature * time on your phone and follow the prompts. On the older systems go in to programming press feature ** 266344 (config) then pswd 23646 (admin) on your key pad this gets you into programming press next until you get to change time. You need an overlay which can with your phone system manual. If need more info please ask agian hope this helps.
SOURCE: We followed the instructions (posted
Go to the link below to get some more help.
http://www.nortel.com/cgi-bin/comments/comments.cgi?key=techsupport_cu
Good Luck
