Watches Logo
Neha Sharma Dayal Posted on Mar 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have this Anne Klein watches that has stopped functioning. Showed it to a repair shop, the guy there replaced the old battery with a new one, still it's not working. It is under the two years warranty. Please help.
Robert Oliver
Level 2:
Sergeant:
  • Expert 323 Answers
  • Posted on Mar 14, 2018
Robert Oliver
Expert
Level 2:
Sergeant:
Answers
323
Questions
Helped
84954
Points
959
If it's still under warranty,
contact the retailer or the manufacturer & let them sort it out.
This is exactly what a warranty is for.
Best of luck
5 Related Answers
Anonymous
  • 203 Answers
  • Posted on Nov 21, 2008
SOURCE: Salesperson cracked the crystal on my Anne Klein watch.
the sales person should replace it . but some horolgists have a machine that cuts new glass. hope this helps joe
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 19, 2008
SOURCE: Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 06, 2009
SOURCE: Lost warranty and information book for Ann Klein watch 107208RMRG
As you lost all the papers , there is no reason to send your watch to any specific repair centre. Just find your nearest watchmakers shop and they will sort the things out.
Alternatively you can pop in to any Anne Klein dealer shop and ask to fix your watch.
Do not forget to rate, please.
Anonymous
  • Posted on Dec 09, 2009
SOURCE: anne klein watch battery replacement
My Anne Klein uses an EverReady #377. The internal time module from Hong Kong is stamped with "AL21E."
I hope this helps you.
Anonymous
  • 2501 Answers
  • Posted on Mar 07, 2010
SOURCE: I can't get the back off of my Anne Klein watch
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Anne Klein 10/7449. What number battery does it take? Thought I had the correct replacement battery, threw the old one away. Yikes, didn't work. Any help will be appreciated.
From Anne Klein themselves.
How do I get my watch battery replaced?
Please take your watch to a qualified local watch repair center or jeweler to have the battery replaced. It is very important that a battery is replaced by an experienced professional who can properly seal the back of the watch to prevent damage to the movement.
Did you look around the battery area with a jewelers loupe. Sometimes is is engraved.
This is my standard response
https://www.fixya.com/support/r27181038-changing_watch_batteries
What size battery for Anne Klein watch 12/6187
Take your watch to a qualified local watch repair center or jeweler to have the battery replaced. It is very important that a battery is replaced by an experienced professional who can properly seal the back of the watch to prevent damage to the movement.
How to adjust Time and Date on Anne Klein 10/7899 6P05 Ladies Watch
You need to pull the crown out 2 clicks and rotate to set time.
1 click and rotate for day/date functions.
Push in fully to lock settings and resume time keeping.
Nordstrom provides a generic Anne Klein manual here:
http://i.nordstromimage.com/images/default/shop/image/misc/watch-manuals/anne-klein/anne-klein.pdf
L have Anne Klein watch and it stopped working, took it to the repair shop and changed the battery and the repairer told me it uses battery no. 317, it didn't stay long before it stopped working...
look for another watch service center, or bring it to the authorized distributor of your anne klein watch. they have what you are looking for. i hope this will helped you.
Sep 05, 2011 • Watches
Anne klein automatic watch, need to replace its time adjustment knob because it was lost... watch repair mans already checked it but cannot open the watch because its too tight..some service center i went...
Anne klein is handled by LUCERNE/CHRONOS SHOP located at Ayala malls like Trinoma in north edsa, Shangrilla in shaw boulevard EDSA, Alabang Town Center in Alabang, Muntinlupa. where is your location so that I can Give you the exact route of malls that near you. i hope i had been helped you.
1helpful
Need extenderfor Anne Klein watch model 10/8031 SVGY.
I would recommend going to a watch repair shop for this. Depending on the style of bracelet there are a couple solutions. I would suggest a shop familiar with or that carries Anne Klein.
Most repair shops will have extender links and clasps. If you have a fashion watch that doesn't have a typical clasp or bracelet set up a Anne Klein dealer will be able to better assist you in getting a solution from Anne Klein.
Precision Time has Anne Klein and they do a fair job of getting parts through their repair center. You can visit their web site at PrecisionTimeCo.Com.
Sep 22, 2009 • Watches
1helpful
I have lost the crystal on my watch. How do I get it replaced?
If this is Anne Klein watch, you have to find your nearest watch repair shop and ask them to order that specific glass. Anne Klein do not supply parts to the customers and the only way to obtain them is through retailer or registered watch repair shop.
Rate, lease.
Top Anne Klein Watches Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
