Garden Logo
Posted on Jul 31, 2009
Pressure washer oil
I have borrowed a troy bilt pressure washer with a honda GC160. I just wanted to know what is the best oil to use in these?
Thanks!
L.
andy just round the corner
Level 1:
New Friend:
  • Contributor 47 Answers
  • Posted on Aug 01, 2009
Contributor
Level 1:
New Friend:
Answers
47
Questions
0
Helped
37207
Points
92
Troy-Bilt 2500 psi / Honda GC160. 5.0 hp. No manual. What weight oil? Straight gas or also mixed with oil?
Hello, I have found this for you. The first link is to the engine manual page and, The second is to an owners manual that may be what you need.
hope this helps. :)
http://engines.honda.com/parts-and-support/owners-manuals/gc160
www.e-barnett.com/ProductDocument/10148/2490717_Owners.pdf
1helpful
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
1helpful
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
2helpful
How do I change oil in my Troy Bilt Model 020245 pressure washer
if its a vertical engine it;s underneath the base of motor look for a plug with a square slot in it i usually use a 3/8 " extension
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
23helpful
2answers
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
17helpful
3answers
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Do I need to add oil to the gas for a Troy-Bilt 2500 power washer
This engine is 4-cycle. It does not require oil in the gas. Is the crankcase full of oil? Do you know how to check it?
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
