Oh boy I hope you're in the UK cuz that is a British unit here are the error code explanations
Error 1
Washing machine door lock has failed to operate or respond
The washing machine has detected an error with the door safety lock or interlock preventing operation.
Check door is closed and latched correctly
Check wiring
Check door lock
Error 2
Water drain time out or failure
The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
Error 3
Not drained in time allowed - washing machine fails to drain water
Error 4
Washing machine has detected problem with the wash heater
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
Check water heating element
Check heater for contunuity
Check thermistor or temperature sensor
Check the thermistor resistance
Check wiring to water heating element
Check connections to water heating element and temperature sensor
Error 5
Check water supply is on, clear and not frozen
Check the air chamber and pressure sensor hose for blockages
Check water inlet valve
Check wiring to water inlet valve
Check connections to water inlet valve
Check the main control PCB
Error 6
Motor heat protector error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit in relation to teh overheat protector within the motor itself.
Check motor connector block
Check motor carbon brushes where fitted
Check wiring
Check tacho connections
Check motor
Error 7
Motor error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
Check wiring
Check motor
Error 8
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
Check for overfoaming or over soaping
Check the air chamber and the pressure switch hose
Check water level sensor
Check wiring to water pressure sensor
Check connections to water level sensor
Check main electronic controller
UNb
Washing machine has detected an out of balance situation
This error code is caused by an imbalanced of incorrect load in the washing machine
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3629-bush-washing-machine-error-codes
