Boating Logo
Dustin Posted on Mar 13, 2018
Will a 60hp evinrude electric tilt/trim work on my 48hp evinrude
Evinrude 2016 135 hp, where is tilt manual release and how to manual release as tilt/trim won't work
I suggest you go to this site and obtain a manual for your Evinrude engine. Hope it helps:
Literature
Jul 21, 2019 • Boating
Removal of power tilt unit on 2007 evinrude 60hp for .repainting
Hello mark,
Remove Engine from Boat.
Loosen Swivel Tube At Top Of Mounting Bracket.
Remove all Ssecuring Bolts On Power Trim Body.
Disconnect Electric Cable.
Move transom Brackets Appart.
Remove Trim Unit.
Hope This Helps
Gordy
Nov 30, 2017 • Boating
Tilt not working on my evinrude outboard
Please, provide your exact outboard type and serial...
Electrical trim/tilt?
Jul 29, 2017 • Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
1978 evinrude will tilt up but not down
Sounds like something is wrong with your tilt and trim motor. You can find some replacements below.
http://www.iboats.com/Evinrude-Power-Tilt-and-Trim-Motors/dm/view_id.269667
Apr 16, 2013 • Boating
3answers
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 • Boating
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
