Measuring Tools & Sensors Logo
Carvel Gipson Posted on Mar 13, 2018
Setting time on modelT83639 sensor Bv2 wireless temperature station
Change Location Digitech XC0366 weather station
Page 6 of the manual refers
DIGITECH XC-0366 USER MANUAL Pdf Download ...
www.manualslib.com > ... > Weather Station
Temperature Alert Setting: You can program your weather station to sound an alert whenever the outdoor temperature exceeds the upper or lower pre-set limit.
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
2helpful
Replaced batteries, outsid temp. does not display
1helpful
2answers
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
What does the Davis wireless weather envoy Map do?
The Davis wireless weather envoy can takedata from a wireless Vantage Pro2 integrated sensor suite or wirelessTemperature/Humidity, or Leaf Wetness & Soil Moisture/Temperature stations,and posts the information to your computer. If you use it with a WeatherLink datalogger and software package it can store data from outdoor sensors. Hope thishelps.
I have Acu-Rite 00754 Wireless Weather Station
Its a remote temperature sensor to read a aquarium or refridgerator or pool water temperature
2answers
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Top Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
