The manufacturer wont part with that info. The manual is listed http://www.taylor-company.com/assets/pdfs/downloadables/C713op0.pdf
and here is the info on the company
www.taylor-company.com/en/contact/
SOURCE: I have a Rheem tanklees water heater, model
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings! 76 76 76 76
http://www.palomastore.com/paloma_error_codes.html
Communication Fault with Remote Control
Check remote control wiring for loose or damaged connections.
Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty).
Replace remote control.
Replace PCB
Replace PCB
Replace PCB
Replace PCB
