SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
SOURCE: AUX Input, very low volume
Try turning the volume up on the pc first, and then the hts volume should be amplified by using its own volume control
SOURCE: Stereo in my Fiat punto
Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
SOURCE: how can I conrol the volume of bose sa 3 amp from the aux input ?
That would depend on the preamp. Name it. A true preamp outputs a variable signal.
It's not clear from the manual what the state of the volume output is without the VCA. Most amps default to full ON and the preamp attentuates the signal with a volume control. Try it with a signal that fades in slowly so you can intervene if it gets too loud. If it's full ON a preamp will control its volume.
SOURCE: DEH-P6800MP Pioneer AUX Input
plug it in right below the sat icon on face it is a 2.5mm plug end so in most cases you need a 2.5mm male to 3.5mm male
