Watches Logo
Ann Wilke Posted on Mar 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How di I set my Casio watch? - Casio Watches
Level 3:
  • Casio Master 18,429 Answers
  • Posted on Mar 13, 2018
Casio Master
Level 3:
Answers
18429
Questions
Helped
1404952
Points
62248
Set casio pathfinder watch
try this site:
http://www.ehow.com/how_5214673_operate-casio-pathfinder-watch.html
1helpful
I just received my watch. There was no manual. I thought the time was set by radio in the middle of the night. It is not set at all. It does not work. Does it need a battery? What do I do? ...
These watches do set themselves during the night. The watch come with a battery fitted so this should not be your problem.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
I need help how to setting my casio 511d watch. I didn't know how set it,
If you haven't got instructions on how to do this, you can get
watches;
Accept terms
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Setting the time
    If you haven't got any instructions, then you can get instructions from the Casio web site.
    Accept terms
    3helpful
    Setting time on a casio sport watch
    Accept terms
    Mar 15, 2010 • Watches
    1helpful
    HOW TO SET THE HANDS ON A Casio AW81D-7AV WATCH
    To get a full set of instructions go to the Casio web site (put "casio watches" and choose the casio web site).
    Select "support"
    Select "manuals"
    Select "watches"
    select "watch manual archive"
    Put your watch number in the box and click on "search"
    HOW TO SET THE TIME
    I assume that the display shows the correct time but the hand do not.
    watches;
    Accept terms
    Top Casio Watches Experts
    k24674
    Robert
    ZJ Limited
    ZJ Limited
    Are you a Casio Watch Expert? Answer questions, earn points and help others
