Seems HP still supports it, lucky you !
CQ60 what you left off the full model number making any accurate answer impossible nor what OS is there, XP?
why not get ethernet wired working first. so you can connect to the internet first then get driver for you unstated wifi card.(chip)
be wise to do that first? ok?
the tell this.
1: what CQ60 model. 100, 200, up to 600
sorry cant guess that>? nor the full service tag data.
learn that 1 model can in fact have 4 options for wifi ,sound,and ethernet chips, (covered in the service tag p/n field !!!)
2: what wifi, internal or USB dongle.
is the wifi same as when new, not upgraded?
3: did you change OS from new, from say XP to vista or W7.
lets play a game , pretend you said CQ60-100
and it told you, its here.
https://support.hp.com/us-en/product/Compaq-Presario-CQ60-100-Notebook-PC-series/3768152
then you said its windows 7-64bit and i said
go here.
then load these drivers. seen here. load all first 7
and skip BIOS
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq60-100-notebook-pc-series/3768152
under network see 3 wireless drivers ,see 3 makers of it.
that means your PC came new with 1 of the 3.
if you dont learn how to see what is in your PC using device manager first, you can only guess.
or try all 3 there, the one that loads and works is IT.
done blind.
again, no service tag presented by you
no OS stated.
and that makes the job 10 times more hard, for everyone.
wifi is not easy.
here are the rules.
1: correct driver, loaded matching wifi chip and OS. (and our unstated PC)
2: find the routers SSID.
3: pick the routers encryption, wep/wpa/wpa2.
4: set the pass phrase of the router. now.
5: connect.
be in range of router not 100 feet way or
behind brick or concrete walls.
in a nut shell, my guess is #1 is hard failure.
Had this laptop myself, you need to remove all the drivers for the wifi and delete the files and folders.. download the driver from HP, reboot the laptop and it should install the windows driver. reboot again and then install the HP driver, when you have done this and its working make sure windows cannot update drivers ever again as windows installs wrong drivers. windows 10 is prone to installing the updated drivers that are not compatible with this model. like mouse pad. max version is 18. windows puts 19 on and it makes over driver incompatible.
SOURCE: xp drivers for compaq-presario-cq60-104tu-laptop
i have compaq presario cq60 104tu laptop and no driver for xp
SOURCE: driver laptop compaq presario cq60
please send u r email ID i will send u the links for it
( siddharth )
[email protected]
SOURCE: Drivers and utillities for Compaq Presario CQ60 140EK
From HP Support site, getting CQ60 to work with XP:
Intel Chipset (install and reboot before other drivers):
http://tinyurl.com/54r6dt
if you have Nvidia video graphics
NVIDIA GeForce 9200
Nvidia ForceWare X 177.98 for Windows XP/2K 32bit, here:
http://tinyurl.com/6dz435
3-step process to install:
1. Download driver, double click and select extract,
2. Download modded INF and replace original INF in extracted folder,
3. Install & reboot.
MS-UAA (required with a reboot before intel Video and Audio driver)
here:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
if you have intel graphics
Mobile Intel 4 Series Express Chipset Family Graphics
http://tinyurl.com/48lunj
Conexant SmartAudio 221
here:
http://www.mediafire.com/?dg0cmmkm4y4
Use this for audio. Unzip to a folder.
Run installer. if it errors use Device Manager.
From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect,
Install from a list or specific location,
Select Don't Search, I will choose the driver to install,
For the Hardware Type select 'Show All Devices'
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".
Ignore XP when it complains.
Reboot.
Conexant HDAUDIO Soft Data Fax Modem with SmartCP Driver
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33839.exe
if you have Atheros Wireless driver
here (your VISTA driver):
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39403.exe
or if it does not work try here:
http://www.megaupload.com/?d=P8I57N0S
if you have intel wireless
here:
Intel PRO/Wireless Drivers
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38890.exe
if you have Broadcom Wireless
here:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39912.exe
Realtek usb 2.0 Card reader:
http://tinyurl.com/2bj95k
Realtek RTL8101E Family PCI-E Fast Ethernet NIC Driver
http://tinyurl.com/4ssd97
.Net Framework(before Quick Launch):
http://tinyurl.com/758p8
HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softpaq/sp40001-40500/sp40139.exe
If you have Bluetooth,
The HP Integrated Module is your Bluetooth Wireless
here:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38983.exe
If you had for 7 unknown devices (buttons drivers)here:
http://www.mediafire.com/?nnnzjmojcjy
Installation --> right click machine.inf, choose install.
Good luck.
SOURCE: webcam not working om compaq presario cq60
try installing the driver and verify the driver has been installed properlly
