Question about Power Acoustik Car Audio & Video
Power acoustik pdn-626b gps error out of memory
NEED VOLUME KNOB FOR POWER ACOUSTIK PDN-626B
Fixya does not sell replacement volume (control) knobs.
Sep 11, 2017 | Power Acoustik Car Audio & Video
My navibox-1 gps keeps saying no signal
HAVING SAME ISSUE.I OPENED IT UP,THERES A SMALL WATCH BATTERY.TURN YOUR CAR ON OR HAVE POWER TO THE NAVI SEE IF IT LIGHTS UP ORANGE INSIDE AND STAYS LIT.IF IT DONT LIGHT UP ITS THE BATTERY.IF IT LIGHTS UP SATYS LIT,THEN COULD BE THE MAP CARD OR CORD.THESE ARE THE COMMON ISSUES,THE 1ST BEING THE BIGGEST
Mar 04, 2014 | Power Acoustik NAVIBOX-1 GPS Receiver
How to fix the13 pin wier card in-- Soundstream VIR-7840NR
Hola...Por que dices que el conector no te coincide??
Si es el que entra en el radio hay dos tipos, uno con 24 pines y otro de 28 pines, yo tube un problema igual y compre el conector adecuado en la pagina de power acoustik.
Jan 23, 2013 | Power Acoustik NAVIBOX-1 GPS Receiver
My power acoustik cant remem song when i turn off my car when
Make sure the yellow wire is going to a source that is still hot when the key is turned off. The yellow wire controls the memory and must have voltage going to it all of the time.
Jul 19, 2011 | Power Acoustik PTID-5850NR Car Video...
I need an owners manual
You can get this with google.
Otherwise ask manualfox.com - this is the hazzle-less way to get it.
Apr 23, 2009 | Power Acoustik PAVN-7210 Car GPS Receiver
Memory full error
power off the GPS, then press power button to power it on, press right-bottom corner of the screen during it power-on, will pop-up a button on screen let you to clear user data.
Jan 20, 2009 | Garmin StreetPilot c550 GPS Receiver
WIRING
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
Nov 18, 2007 | Power Acoustik LT-980/2 Car Audio...
Car Audio & Video Logo
163 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
