SOURCE: pride power chair jet 7
Have the batteries load tested. Most likely they need to be replaced.
SOURCE: Hoveround MPV 5 - Used Power Wheelchair: i have a hoeround xhd and pickup lift where does t...
You will need tie downs to the power chair. It is a metal piece the fits over the chair post and sits under the seat and had two metal loops to hook on to. The Hoveround field technician will install it for you.You need to order the tie downs from Hoveround, your insurance will most likely NOT cover the cost.
SOURCE: CAN'T LIFT OFF SEAT OF JET3 POWER CHAIR? batteries
Richard The seat is probably rusted on the seat post It will take alot of turning and pulling upward at the same time to get it off. Try spraying a penetrant on the post just below the seat to see if that will help with the turning and pulling just keep at it. It can be a tedious task and frustrating Hope this helps
